Environmental rating for CAB-ETHRJ45-M12-10 (M12 to RJ-45 Ethernet cable for IW3700 Series APs?
Muhammed Adnan
Level 4
Level 4
Hello Experts,
Can someone please confirm on the environmental ratings for CAB-ETHRJ45-M12-10?
https://www.cisco.com/c/en/us/products/collateral/wireless/industrial-wireless-3700-series/datasheet-c78-734968.pdf
I don't find any documentation for this part number from Cisco for the operating temperature and IP ratings for this cable and its suitability in outdoor conditions.
heaviles
On the M12 side that connection is rated IP67, on the RJ 45 side it is IP20 for this assembly.
Hope this helps.
Do you have information about the PoE IN Port? The cable connector should be a M-12 X-code connector male or Female?
I found two differents types of connector in two datasheet.
https://www.cisco.com/c/en/us/td/docs/wireless/outdoor_industrial/iw3702/hardware/install/guide/b_iw3702_gsg.pdf
On page 76
The PoE IN port is a 8-pin M12 X-code female connector
On page 13
Input power requirements: PoE and PoE+ (M12 8P female connector with X-coding per IEC 61076-2)
Clould you please tell me what type of connector M12 is that the clable CAB-ETHRJ45-M12-10 has?
Does anyone know if the CAB-ETHRJ45-M12-10 cable is included with the AP IW3702 series and how many parts are included?
