Error code 10 on dot11Radio interface
talel-haddad
Community Member
Hello , i have configure my Cisco Aironet Access point and the dot11Radio interface keeps restarted automatically with error code 10.
i have already update the IOS image to the latest version , but still encounter the same problem .
"15.3" is the code train (major release number) not the actual version number of the release you're using.
The latest release of software for the 702i is 15.3.3-JK11 - is that what you are using?
If not then update to 15.3.3-JK11.  Any bugs still found in that release are very unlikely to ever be fixed because that is likely to be the last release and all of the autonomous AP models are now end of support.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
10 Replies 10
Mark Elsen
                   - Check logs on the AP when that happens ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
What is the model of the AP, is it a 2700/3700?
it is cisco aironet 702i , and it  is end of life access point
Rich R
@talel-haddad  What version of software is it running? ("i have already update the IOS image to the latest version" is not helpful!)
And also what model of AP? (as Leo has already asked)
If the radio crashes then you should see an event file on the flash which contains info like a crashinfo file which should help understand why it's crashing.
cisco Aironet 702i with image version 15.3
If this is a x700 AP, post the complete output to the command "sh ip interface brief".
thanks it was the release software problem , i thought it was the latest version of the software i have download  .
thanks everyone for your help .
Glad to hear you found the solution.
That's why it's always essential to state the exact full version number of the software you are using @talel-haddad
Mark Elsen
            - Post screenshot of this error ,
 M.
