[ERROR] dhcp_proxy.c 2897 on Wireless LAN controllers
SHANNON WYATT
Level 5
Level 5
I get the following errors on all of the Wireless LAN controllers I have configured:
Thu Oct 27 14:08:41 2005 [ERROR] dhcp_proxy.c 2897: Received a packet from ourselves, network loop!
Thu Oct 27 14:08:26 2005 [ERROR] dhcp_support.c 357: dhcp_bind(): servPort dhcpstate failed
Thu Oct 27 14:08:26 2005 Previous message occurred 226 times
The network is configured as such:
Controllers are connected to trunk port on a 3750 Switch with all of the VLANs configured. Helper addresses are on most of the VLAN interfaces. I assume that I get that error because the VLAN interface is answering the DHCP request as well as the DHCP proxy in the controller. Is that the issue?
thomas.chen
Level 11
Level 11
This is a known issue. To resolve this issue Configure a bogus IP address on the service port and disable DHCP. Make sure the IP address is a completely different network than the manager or ap-manager interfaces. Hope this helps.
