Error in Prime Infrastructure 2.0 after Controller upgrade
patoberli
Hello
I've got two WiSM and Prime Infrastructure 2.0. Last week I upgraded one WiSM to 7.0.250.0, plus a third controller. That worked fine, but since then, my PI shows one of the two controllers of the second WiSM as "Unreachable". I rebooted the PI and also rebooted the controller again, to no avail.
I tried now to update the snmp v2c credentials in PI, but receive an error.
The error message shown when I try to update the credentials is:
Error: Common-1: Some unexpected internal error has occurred. If the problem persists please report to the Tech Support.
Error:Detail: errorId=6 Invalid credential name: snmp_transport.
Any ideas?
I can normally access the controller through its webinterface and don't see any errors that would spring to the eye.
[edit]
Just manualy run the Task "Controller Operational Status" and received this error:
com.cisco.wnbu.server.common.errors.InternalException: COMMON-1
Patrick
patoberli
I worked with TAC Team and the final solution was to delete all controllers and add them again. This might get fixed in a future version though.
It's works! Thanks for quick reply ;)
Why I can not Delete Device and update credential is error .
PI 2.2  WLC 7.6.130.X
