Error installation for webauth
juergen.neumann11
Community Member
I would like to install a web auth certificate on a 5508. Version 7.6.130
Every time I get an error on web gui or cli like:
Cisco Controller) >transfer download start
Mode............................................. TFTP
Data Type........................................ Site Cert
TFTP Server IP................................... 10.1.126.100
TFTP Packet Timeout.............................. 6
TFTP Max Retries................................. 10
TFTP Path........................................ /wlan/
TFTP Filename.................................... final.pem
TFTP Webauth cert transfer starting.
*TransferTask: Oct 07 14:33:08.162: RESULT_CODE:1
*TransferTask: Oct 07 14:33:12.165: Locking tftp semaphore, pHost=10.1.126.100 pFilename=/wlan/final.pem
*TransferTask: Oct 07 14:33:12.249: Semaphore locked, now unlocking, pHost=10.1.126.100 pFilename=/wlan/final.pem
*TransferTask: Oct 07 14:33:12.249: Semaphore successfully unlocked, pHost=10.1.126.100 pFilename=/wlan/final.pem
*TransferTask: Oct 07 14:33:12.250: TFTP: Binding to remote=10.1.126.100
*TransferTask: Oct 07 14:33:12.266: TFP End: 7959 bytes transferred (0 retransmitted packets)
*TransferTask: Oct 07 14:33:12.266: tftp rc=0, pHost=10.1.126.100 pFilename=/wlan/final.pem
        pLocalFilename=cert.p12
*TransferTask: Oct 07 14:33:12.266: RESULT_STRING: TFTP receive complete... Installing Certificate.
*TransferTask: Oct 07 14:33:12.266: RESULT_CODE:13
*TransferTask: Oct 07 14:33:16.269: Adding cert (7895 bytes) with certificate key password.
*TransferTask: Oct 07 14:33:16.309: RESULT_STRING: Error installing certificate.
*TransferTask: Oct 07 14:33:16.309: RESULT_CODE:12
What's funny, when I'm on a 2106 with the same certificate (Version: 7.0.250.0) install, everything works!
Does anyone have an idea to solve this problem?
Juergen
0 Replies 0
