Error Setting Country Code
aeryilmaz
After a factory refresh on a 3602i, I am no longer able to set the Country to "US"
It is defaulting to "AU" and when I try changing it I get the error that reads "error in setting country code."
Any thougths on where to start with this?
The AP was purchased in the US and had previously operated under that country code. It's only after the factory refresh that this became an issue.
Version is  7.4.100.60
If you have correct Country code on WLC then please factory Default the AP and then try again.
Before you can change the country code of a WLC, you must disable the 802.11a and 802.11b network :
>config 802.11a disable network
>config 802.11b disable network
Now you can change the country code of the controller. For example, we change it from US to IN (INDIA)
>config country US
After changing the country,enable the 802.11 interfaces.
>config 802.11a enable network
>config 802.11b enable network
If still problems then pase the output of the command:
WLC:
Sh sysinfo
AP:
sh inventory
6 Replies 6
Sandeep Choudhary
You can't change a country code on an access point but you can add the country code to the wlc.
You should be able to see in the logs if the ap has the wrong country code, mismatch with the wlc out there. You need to verify you are using the correct ap in the country it is being used in.
paste the output of sh inventory form AP.
Just to add.... what does the label on the underneath of the AP or the label on the box show as far as ap model.  That will tell you what the country code of the AP is also.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Country of origin is US
And, it was working prior to the factory reset.
I should've mentioned that it is from the WLC that I am trying to change the Country Code.
>config country US
WLC:
Sh sysinfo
AP:
sh inventory
To truly factory reset, you need to erase the nvram.  If the model number is US, then it should be US as the AP country code can't be changed.  Factory reset of the AP doesn't mean that you can change the country code of the AP, but you can always add or remove a country code from the WLC, which is global to the WLC and not making direct changes to the AP.
debug lwapp console cli
or
debug capwap console cli
erase /all nvram
Example:
Entered the username and password
erase /all nvram:
[confirm]
undebug all
reload
[confirm]
Hold reset for over 30 seconds to get to ROMMON
ap:delete flash:private-config
ap:delete flash:private-multiple-fs
ap:boot
Your AP will be factory default
Scott
-Scott
Hi all - thanks for your replies! They were much appreciated!
I did another factory reset on the AP, this time using the "hard reset" option from the controller. After the reset, the AP re-joined and I am now able to specificy the correct country code.
Thanks again!
