Error while trying to customize Web Authentication
talmadari
Level 3
Level 3
i have tried to customize the web auth portal on a WLC running v5.2.110.0.
i have compressed the login files (images and html code) into .tar file with picozip and tried to download it to the controller.
i'm getting the following error:
*Feb 04 17:47:07.236: %UPDATE-3-FILE_OPEN_FAIL: updcode.c:2408 Failed to open file login.html.
*Feb 04 17:47:07.236: %OSAPI-3-FILE_OPEN_FAILED: osapi_file.c:469 Failed to open the file : /mnt/application/webauth_ramdisk/login.html.
-Traceback: 104b7590 10012724 1001015c 100148c8 104be944 10e42470 11033dec
Did anyone managed to customize the web auth portal?
bwilmoth
Level 10
Level 10
Check if the path mentioned using the path statement is correct. If your image is in the root directory of the tftp server your path statement on the controller would be /. If the image is in the wireless directory of your tftp server then the path would be /wireless.
