Errors msg IN AP
Ibrahim Jamil
Level 7
Level 7
Hi Received the below message from the AP 1200
The system has been encountered an error initializing
ethernet port. You may need to check hardware
The system is ignoring the error and continuing boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet, tftp, and finish
loading the operating system software:
    ether_init
ether_init
    tftp_init
    boot
Also it hang  at the below line thus am not able to access the CLI
*Mar  1 00:00:40.707: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
11 Replies 11
Surendra BG
make sure you are using the right console cable and on the hyperterminal use the restore defaults settings.. if we are still facing the issue.. then this is a hardware problem and needs to be replaced..
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
Please consider this into account
the AP is on my desk coonected via console while no ethernet cable connected to switch also no Antena on the AP it self,now what am just need to enter the CLI witch isn't
ok.. i hope we are using the right console cable and the make sure the Baud rate and rest are using Restore default settings..
Surendra
Surendra BG
dude,i m using Cisco console cable and i tried many also but with same result and my Baud rate is 9600
ok.. have u tried using the least baud rate?? and then kep increasing the baud rate and give a try..
Surendra
Surendra BG
freind,i have msg on the console but it hang at the bvi interface
Scott Swist
Ibrahim,
I have experienced this error before and it is indeed a hardware error and it hangs on that line in the console session because of the hardware error.  you will need to replace or have the unit repaired.
Hope that helps,
Scott
Please rate this post if you found it useful.
hi scott maybe its hang here bocoz no antena on ap and no ethernet connection,maybe becoz of that?
---how to repair this AP
thanks
No.. there is some problem with the hardware.. if the Antennas and the Ethernet are not connected we do not face this issue.. AFAIK ..
Surendra
Surendra BG
How to add network hock
Ibrahim,
No, it won't hang at all for no antenna or no ethernet connection.  It is definitely because of that init error.  And that is definitley a hardware problem with the ehternet port that ehternet init is the self test for the ethernet port when the radio powers up if it fails it will hang.  The only way I know to get it repaired is to call TAC.
Sorry my friend,
Scott
Please rate this post if you found it helpful.
