Ethernet Error : 44 Misses
tspilman
Community Member
One of our WGB350's is constantly (every 5 seconds) sending this error to our Network Management Station. We've replaced the radio but get the same error. Out of 12 WGB350's this is the only station that reports this error. The number of Misses varies from 6 up to 75. Any Ideas?
murabi
Level 8
Level 8
Did you try new (known good) cables? It definitely seems to be physical layer.
I found this...
"Misses: The number of Ethernet packets lost due to lack of buffer space on the unit."
Quoted from:http://www.cisco.com/warp/public/102/wlan/errors.html#ethernet
