Setting up a wireless bridge solution
pcarbonneau
Community Member
I have received a requirement from my customer wich they are interested to install a wireless bridge between 2 locations. the approx. distance are half of mile.
As regard to the information I have, Cisco have some Aironet 350 Wireless Bridge Access Point product that can do the job, since the distance are very
close, can we provide a wireless bridge solution that will be based on 802.11a
standard ? if so does Aironet 1200 can be utilized.
I will appreciate if you can provide me some technical recommandation or some weblink as regard to setting up a wireless bridge solution.
Cheers
tepatel
You need to use 350 series Bridges. Bridges are not available in 1200 series ..only Access Points are availabe in 1200 series..
Here is the link to FAQ for 350 series bridges
http://www.cisco.com/warp/public/102/wlan/bridge-faq.html
Also
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/350brdgs/index.htm
