Failed DTLS handshake and rejoining
frederick.mercado
9 Replies 9
Rich R
I noticed this in the 17.8.1 release notes - try 17.3.5a and don't forget the CSCwb13784 SMU for the MTU issue?
CSCwa35350
AP flaps when WNCd to which it maps report high CPU utilization.
ammahend
In the bootflash, do you see any crash file ? if you do you can run more, it might give you insight into why the AP crashed and you will have a better direction to work on the fix.
here is an example, while led to a bug :
9800#dir bootflash-2:
Directory of bootflash-2:/
24505 -rw- 158219 Feb 9 2022 18:05:12 -06:00 AP_D103.crash
24504 -rw- 74914 Jan 21 2022 00:43:53 -06:00 AP_E107.crash
9880#more bootflash-2:AP_D103.crash
AP_D103.crash crashed at Wed Jun 30 22:20:17 2021 UTC(BOOT_CNT 36) due to:
FIQ/NMI reset
hope this helps.
-hope this helps-
Hello All,
I am also facing the same issues in our 9800 WLC,some 3800 WAPs are disconnecting and rejoining for every 2 mins.
*Jun 7 02:20:46.207: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: Session-IP: 10.200.38.55[5256] Mac: 6c31.0e8a.c900 CAPWAP
DTLS session closed for AP, cause: DTLS server session shutdown.
Pls could someone help here
What version of IOS-XE?
What do you see on the AP logs?
IOS-17.3.4c
                           >...could someone help here ?
 - Did you already check the (previous) replies in the thread.
   For the rest you may  have the current controller configuration reviewed with (CLI) show tech wireless : have the output analyzed by https://cway.cisco.com/tools/WirelessAnalyzer/
  Look for hints and advisories , not use command as mentioned in green , do not use traditional show tech-support , for Wireless Analyzer.
 M.
I believe we resolved our issue by increasing the WLAN timeout session in the policy to 86400 and idle timeout to 3600 sec
hara12386
Can you please confirm how you changed the timeout?
Many thanks,
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-9/config-guide/b_wl_17_9_cg/m_config_model.html#task_lv2_g5n_kz
