Failed to add device to WCS Reason: Object not found in device
endpoint
Hi i am adding wlc (ver 7.0.116.0) to WCS (ver 7.0.164.0) and getting bellow error message.
This controller was successfully added to the WCS before upgrading WLC ios to 7.0.116. Now i am unable to communicate with the controller thru WCS. The controller itself work ok and serve all WAPs with no issue.
Any ideas would be appreciated.
Regards.
hogoqo
You will need to upgrade WCS to Version 7.0.172.0. WCS version 7.0.64.0 does not support or manage WLC version 7.0.116.0. Hope this helps.
hogoqo
