firmware
cumunidad me pueden apoyar con firmware 15.3.3 standalone industrila wireless access point
Rich R
Google translate: "community can support me with firmware 15.3.3 standalone industrial wireless access point"
I guess you're asking if somebody can provide you with 15.3.3 IOS (firmware) for an access point?
NO - Cisco software is only available to download for licensed Cisco customers with software support contracts (or for some products with lifetime support included or specific security defects).  Sharing is not allowed.
Also you need to know the exact model of AP before you can look for the software and you need to know exactly what release you are looking for (there are many 15.3.3 releases).  For example the latest release for the Industrial Wireless 3702 Access Point is at https://software.cisco.com/download/home/286287624/type/284180979/release/15.3.3-JPK1
If you don't have access to that you could try contacting the reseller you bought the AP from or sometimes a search for the file name can be helpful.
You could also read the Customers Without Service Contracts section of https://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20190717-aironet-dos very carefully and then contact the Cisco TAC via email with the requested information to ask them to provide a fixed version of software for your AP.  You must refer to the URL of that advisory otherwise your request will not be considered.  The full list of fixed releases is at https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg95745
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
