Flex Connect and Mobility Express
Denniz
Level 3
Level 3
Hello there! I am new to FlexConnect (Officeextend) and i am wondering how it works. If i configure flexconnect, does the access point outside LAN create a VPN tunnel to my LAN or does it just brodcast the ssid's and do SSID to VLAN mapping? Will it also work with mobility express? Can i use mobility express as an officeextend controller?
2 Accepted Solutions
Mark Elsen
 - Flexconnect is not the same as Officextend , in flexconnect you have 'only' that client traffic is locally switched , check some differences here : https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/flexconnect.html
                            https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/configuring_officeextend_access_points.html
    M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
- By default APs operate in "Local Mode" where all SSID traffic is tunnelled to the WLC over CAPWAP and switched centrally on the WLC.
- Flexconnect Mode allows SSID to be configured with local authentication and/or local switching whereby traffic no longer needs to be tunnelled to the WLC - AP simply switches it onto a local VLAN where the AP is connected.
- Office Extend is designed for deploying a corporate (centrally switched) SSID on the AP while also allowing the user to have a user managed local SSID for general internet access which is locally switched.  The user has a basic GUI they can access to configure their local SSID on the AP.
- Mobility Express only supports flexconnect local switching - no central switching because AP does not have enough CPU for central switching.
- "Will it also work with mobility express? Can i use mobility express as an officeextend controller?" I doubt it (but don't know the actual answer) - and why would you even want to do that?  ME is designed for small local networks - not remote AP deployments.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Mark Elsen
    M.
Rich R
Denniz
Level 3
Level 3
Thanks to both of you!
And @Rich R, I am not going to deploy it, i was just wondering!
