Flex Connect Group help
Andy White
Level 7
Level 7
We have a few FLex Connect Groups setup (not by me) and I have just created one for the first time on our 5508 WLC.
I used the GUI and all the settings look the same as the other Flex Connect groups about from what is under the tab called "WLAN VLAN Mapping"
In there is should show the 2 SSIDs.  I have attached an image of a good Flex group and the one I'm doing, how do I add the 2 SSIDs?  You can see where I have put the cross that the 2 WLANs are missing.
Rasika Nayanajith
Under the WLAN Advanced tab, have you enable "FlexConnect Local Switching" ?
Rasika
Where is this advanced tab?
From the WLC GUI:
on the top navigation select "WLANs", go into each of your WLAN's and click the "Advanced" tab, scroll down about 2/3 the page to the "FlexConnect" section and enable "FlexConnect Local Switching"
