Flex connect issue
qsosan20
Level 3
Level 3
Hello Experts ,
I have an AP that's operating in Flex mode and registered to 9800 WLC ,
After complaining from clients that random disconnections happening to wifi , i took debugs for one of the clients at the disconnection time and found that client has been disconnected due to AP was unregistered from WLC due to a connectivity issue , now my question if AP operating in Flex mode and SSID policy also in Flex mode , hence even if ap disconnected from wlc , client should continuo operating normally as per my understanding to how FLEX mode works , is that correct ?
7 Replies 7
Leo Laohoo
Reboot the AP.
If problem persists, reboot the controller.
It could be CSCvx56223.
Hi Leo ,
Thanks for your reply ,
I will reboot the AP for now and see ,
For the bug its affecting 17.3.3 and earlier , however my AP is
17.3.5.43,
Always assume the bug affects all version.
JPavonM
@qsosan20 yes your assumption is right, clients should keep connected to a Flexconnect AP even when the AP is disconnected from WLC, but new clients won't be able to connect unless you have configured local-authentication in the Flex profile.
Thanks for your conformation @JPavonM
Mark Elsen
  - Yes , client should be able to continue working on a flexconnect based AP
     Check controller software version installed and consider 17.12.3 as latest advisory version
     especially if you are on an older release currently
  + Always useful :  -  Have an overall checkup of the  9800  WLC controller's configuration with the CLI command
       show tech wireless and feed the output from that into Wireless Config Analyzer
      use the full command as denoted in green , do not use a simple show tech as input for this procedure
                   (Actually you may consider the above mandatory when working with 9800 controllers)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
IOS-XE 17.3 is effectively end of life:
https://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-xe-17/ios-xe-17-3-x-eol.html
Upgrade as per the TAC recommended link below.
If the WLAN is using local switching, authentication, association and DHCP then it should continue operating in standalone mode.  You should have:
no central association
no central authentication
no central dhcp
no central switching
configured in the wireless profile policy for the WLAN.
What type of authentication are you using on the WLAN?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
