Flex Connect Smart Phone Issues
Roger Alderman
Level 5
Level 5
Hi All
I have a 5508 controller with 7.4.100.0 code supporting Cisco 1142N and Cisco 3602I and Cisco 3602E APs.
I have flex connect set up with a guest WLAN configured with web auth.
I am using local switching and central web auth.
A laptop connects fine to the guest SSID.
An iPhone and Android phones fail to get an IP address.
An Android tablet shows the same issue.
Anyone seen this before?
Roger
8 Replies 8
Scott Fella
A few things here. The version you are on isn't a good code. I suggest looking at v7.4.121.0. Since this is WebAuth and other devices are fine... Does the devices see a splash page or doesn't get that far because of not getting an IP? Can you post your show WLAN
What state is the client in also?
-Scott
Hi Scott
The WLAN is configured as Open with Web Auth. FT is disabled.
The client doesn't get an IP address so no splash page as yet.
The client is an Web-Auth Reqd state.
Roger
I have many customer where I'm also doing FlexConnect and using the WLC for WebAuth and I have not seen an issue like that at all.  Either all the devices have issue or none... Is the issue with all iPhones and iPads or a few?  Can you post the show wlan
You are not anchoring or are you?
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Hi Scott
Here's the relevant info:
Show WLAN 2
WLAN ident = 2
Profile Name = xxxx
SSID = xxxx
Status = Enabled
MAC FIltering = Disabled
Broadcast SSID = Enabled
AAA Policy Override =Disabled
NAC = All options disabled
Max clients per AP radio = 200
Number of active clients = 12
Exclusion timeout = 60 secs
Session timeout = 1800 secs
User Idle timeout = 300
User Idle Threshold = 0
NAS Ident = Hostname of WLC
CHD per WLAN = enabled
Webauth DHCP exclusion = disabled
Interface = management
Multicast interface = not configured
WLAN IPv4 ACL = none
WLAN IPv6 ACL = none
mDNS status = enabled
mDNS profile = none
DHCP server = default
DHCP address assignment required = disabled
Static IP client tunneling = disabled
PMIPv6 mobility type = none
QoS = silver
WMM = allowed
WMM UAPSD = disabled
Media stream multicast = disabled
CCX Aeronet IE =enabled
CCX GPR = disabled
CCX Diagnostics = disabled
Dot11 phone mode = disabled
Wired Protocol = none
Passive client feature -= disabled
Perr to Peer blocking = disabled
Radio Policy = all
DTIM = 1
Radius Servers = none
8021.11 auth = open
FT support = disabled
Web Based Auth = enabled
No Web Based ACLs
Web Auth Server Precedence = Local
Web Passthrough = disabled
Conditional web redirect = disabled
Splash page web redirect = disbaled
Auto Anchor = disabled
Flex Connect Local Switching = enabled
Flex Connect Central DHCP Flag = disabled
Flex NAT-PAT flag = disabled
Flex DNS override = disabled
Flex VLAN based VLAN switching = disabled
Flex local auth = disabled
Flex learn IP address = enabled
Roger
Roger,
The WLAN looks fine... nothing has changed on the WLAN and this has been working for a while?
Scott
-Scott
Rasika Nayanajith
Hi Roger,
As Scott sugested upgrade to 7.4.121.0 & start troubleshooting.
Knowing the code you are running is buggy, not point spending lots of hours to troubleshoot with a code like that. Also upgrade your FUS to 1.9.0.0
Rasika
**** Pls rate all useful responses ****
The issue was an extremely strange problem with a DHCP Server.
It was resolved by temporarily moving the DHCP scopes onto the firewalls.
The DHCP Server just happened to have issued IP addresses to the test laptops but then stopped working.
The server is currently being rebuilt.
Roger
So since the issue was with smartphones only, was it due to the lease for those addresses?
-Scott
