ios 7.0.x SSID problems
Mathieu Sturm
Level 2
Level 2
We're having a problem with ios devices for some time now. When connected to an SSID on the iPad I can't switch  to another SSID. I have to use the button "forget this network" to connect with another SSID. Are there others that are facing this problem? It looks like it's not even trying to connect to the WLC.
Scott Fella
You need to make sure you have Fast SSID Change enabled on the WLC. This can be found in the WLC GUI under The controller tab.
-Scott
Scott Fella
-Scott
Thank you Scott, that did the trick
Good to know... Glad that worked for you!
-Scott
