Flexconnect deployment issue
moti haim
Frequent Visitor
Frequent Visitor
Hi.
I have two WLC 5508 in HA, configured with WLAN for local switching and flexconnect APs.
i'm running code 7.4.121.0
i'm using ISE for authentication and NAC policies.
under the WLAN, radius NAC is configured and sometimes authenticated clients obtain an IP address from DHCP server but lossing connectivity to default gatway and so on.
After disabling radius NAC on the WLAN everything looks just fine.
is someone know about any bug related to that?
on any release note after 7.4.121 and even 8.0 there are many bugs related to flexconnect.
what is the best software release for using this deployment?
Rasika Nayanajith
Unless you really required this RADIUS NAC feature, you can simply untick that check box. Here is 8.0 RADIUS NAC configuration details which listed some limitations
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_0110001.html
I remember during an ISE troubleshooting they recommend to enable it on our dot1X WLAN, but we did not do that as some limitations listed as it not support with "vlan select" which we are using.
I think you should reach TAC to find specific bug detail related to the behavior you experience.
Rasika
**** Pls rate all useful responses ****
Thank you.
i really need some general information regarding the best software release with flex connect.
i have a lot of deployments with Virtual controller and flexconnect and i cant find stable release.
just for example:
in 7.4.121
CSCud44269 - Roaming breaks for clients associated to the access point
in 7.6.120
CSCuj61455 - Clients get disconnected from FlexConnect AP
in 7.6.130
CSCun20768 - Clients are unable to associate to flex mode local switching WLAN.
in 8.0
CSCuj61455 - FlexConnect clients are being deauthenticated for an unknown reason
Out of all these code, I think you have to end up with 8.x as that will be the code Cisco put some effort to fix known bugs.
In other codes they may or may not..
Rasika
