Flexconnect on Slow Links
We had a deployment of centralised WLC (earlier 3504) with flexconnect configured for remote sites (centralized auth, local switching, ISE CWA. ISE, WAPs and clients are on same LAN). These sites are connected to the controller using satellite links (latency 700-800 msec). That was working without issues.
We migrated the WLC to 9800-CL on Azure (same latency) and started facing issues with CAPWAP throttling by the controller.
My questions:
- Are these messages triggered by the latency between WAPs and WLC.?
- Are there any tweaks for timers to overcome these errors? Please suggest.
- In 9800 can we have local auth or it has to be center (this was a must in 3504)?
Here are sample messages:
May  8 09:58:41.373: %CAPWAPAC_SMGR_TRACE_MESSAGE-4-AP_MSG_THRESHOLD: Chassis 1 R0/0: wncd: Warning : Mac: 1cfc.17c6.5440 Session-IP:x.x.x.x[5273] x.x.x.x[5246] Capwap messages are queued for longer than 21 seconds, turning on client throttling. Queued messages : 36
May  8 09:58:58.661: %CAPWAPAC_SMGR_TRACE_MESSAGE-4-AP_MSG_THRESHOLD: Chassis 1 R0/0: wncd: Warning : Mac: 10a8.2980.1da0 Session-IP: x.x.x.x[5275] x.x.x.x[5246] Capwap messages are queued for longer than 20 seconds, turning on client throttling. Queued messages : 26
May  8 09:59:04.104: %CAPWAPAC_SMGR_TRACE_MESSAGE-4-AP_MSG_THRESHOLD: Chassis 1 R0/0: wncd: Warning : Mac: 70b3.1780.37e0 Session-IP:x.x.x.x[5264] x.x.x.x[5246] Capwap messages are queued for longer than 20 seconds, turning on client throttling. Queued messages : 23
15 Replies 15
So I think that confirms my suspicion - your problem is high CPU not those messages.
We have 9800-80 and even there WNCd can go high (see separate discussions about 9800 architecture and capacity potentially not being up to datasheet specs)
There are literally dozens of things which can cause high CPU - anything which requires CPU processing...
What features are you using (anything not default you have turned on)?
Are you using web auth?
ucode_pkt_PPE0 - that's the QFP emulation which 9800-L runs on CPU and it is normal for that to be >100% but it could theoretically consume excessive CPU if your traffic levels got very high, but more likely need to focus on CPU based processes rather than that one which is packet switching.  Check:
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-cl-wireless-controller-cloud/221058-understand-high-cpu-usage-reported-for-t.html
If it's data traffic (packet switching) causing it then you need to work out what's causing that.  Otherwise it's a case of tuning control plane features to minimise impact on CPU.
