FlexConnect SSID
Mohamed.Ashraf
Level 2
Level 2
Hello
I have a lot of branches (DR) connected to HQ through WAN, and there are at least 3 access points in flexconnect mode with  own SSID at every branches , and every this working fine.
when i click on wireless button at my laptop i found all SSID breaches appeared to me, can i specific for every branch to appear one SSID for it.
Thank you
2 Accepted Solutions
Create an AP Group for each location.
Add only the WLAN(s) you need per location to the AP Group for that particular location.
Add APs at each location to relevant AP Group.
Hi @Mohamed.Ashraf
As other community members suggested, Create a Separate AP group for each of your branches. Move the Branch APs in to the respective group , Then make SSID and APs as flex-connect, so that only authentication traffic will come to WLC incase of centralized radius environment or PSK based SSID.
Refer : AP Group Cisco WLC
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
5 Replies 5
aogston
Level 2
Level 2
aogston
Level 2
Level 2
Hi.  Create an AP group (maybe 1 per location), add the WLAN's you need in that location, and then the AP's in that location.
hi
I need access points at location X advertise one SSID  for this location not all SSIDs at wireless lan controller.
Hi @Mohamed.Ashraf
