FlexConnect WLAN Vlan Mapping - Native VLAN
dot1x
Level 5
Level 5
In FlexConnect groups, does the Native VLAN need to be the same as native VLAN on the switch the APs are connected to?
 Yes, it is.
O doc below, you can see that the same native vlan configured on Switch will be used for configure the AP side.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-2/config-guide/b_cg82/b_cg82_chapter_010010101.html
