flexible radio assignment
Moudar
I have a classroom with about 35 devices (Ipads and laptops connecting to 5GHz), when all are connected and students are doing what they have to do, the channel utilization is reaching 80 and 90%. So my idea was to use FRA to share the load on 2 5GHZ radios. AP is 2802 and WLC 5520 running 8.10.181.3
When i manually changed the 2.4 radio to 5GHz everything was fine until the next class that the students had!
I was sitting and watching the AP on the WLC GUI (Access Point View)
The problem I had was that many devices jumped all the time between the two 5GHz radios the students had a very bad experience when that was happening. (The devices were settled, no one was moving around) the AP is placed in the middle of the classroom ceiling.
What is Throughput in the picture above? When all were connected Throughput was about 3 Mb, up and down
20 Replies 20
I will create a new RF profile with 24Mbps mandatory and check if it will be better.
Why should "Noise" increase when channel utilisation increase a little bit:
24 Mb should be mandatory or disabled? On 5GHz, 2,4GHz or both? Today we run our WLC with 18Mb mandatory on 5GHz and 12Mb mandatory on 2,4GHz.
I think it's worth trying higher data rates in some crowded places with RF profile!
I'm talking about 5GHz. We use 24 Mbps Mandatory and all lower data rates disabled.
In both 2.4- and 5.0 Ghz, disable all data rates from 11 Mbps and below.  Make 18-, 36- and 54 Mbps Mandatory and the rest are Supported.
eglinsky2012
Check out this bug, "High channel utilization on 5GHz radio with 40Mhz". It's fixed in 8.10.185.0.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwb51757
On that note, I forgot to ask, are users experiencing slowness, or did you just notice that high utilization was reading high?
As for throughput, what you showed in the original screenshot is the current measured amount of traffic the radio is passing, not what it's capable of or what the clients would show on a speed test. You mentioned 3Mb up and down. Was that a speed test done from the client device?
This is interesting. maybe it is time to upgrade.
3Mb is what WLC showed under "Throughput" When many clients were connected.
