02-17-2006 04:13 PM - edited 07-04-2021 11:39 AM
Hi.
I've 2 PC's comunicating on IPv6 through an AP Cisco 1200. Everything's fine except that messages, called Router Advertisements (RAs), are not being forwarded by the AP.
I tought that might be because this RAs are being sent to the multicast L2 address "33:33:00:00:00:01".
Is there any command to enable this messages to be forwarded?
Any help?
Thanks in advance,
Tiago.
02-18-2006 06:41 AM
The only setting that comes to mind is the 'Reliable Multicast to WGB (Workgroup Bridge)'
I don't think it applies, but it could be worth a shot ... stranger things have happened.
I know that in the LWAP arena, multicasts & broadcasts are transmitted outside the tunnel, so the routers must be configured to forward specific broadcast/multicast messages.... perhaps you're seeing some varient of that behaviour.
Generally speaking, PCs shouldn't care about route/router advertisements..... have you captured the wireless traffic stream to confirm that your RAs are not passing?
Let us know
Scott
02-20-2006 10:19 AM
Yes, i was captruring packets on both pcs with ethereal. when i use an hub or switch to connect them, the second pc receive the RAs from the first one. but when i use the AP the packets don't get the second pc, but i steall have connectivity between them.
Thanks for the answer,
Tiago.
