1400 Bridge Problem
rx33328
Community Member
I am installing a point to point bridge link using 1400 briges w/power injectors. The bridges are installed but the link goes up and down about every few minutes. When it does connect, it starts out at a low dbm but eventually ends up in the 80's and then loses connection again. We installed a couple of other briges in another location and didn't have any problems at all. I know the distance between sites is way withing specs and there is nothing that could block this link. Any ideas as to what could be causing this. Thanks...
mchin345
Level 11
Level 11
Well, there can be many reasons why this happening. First there could be some issue with the configuration specifically authentication parameters, WEP keys, role of bridge configuration and so on. If you are sure sure that the configuration on both ends of the Bridge are perfect, and if the connectivity between the bridges is intermittent the problem may be RF interference, CRC errors and so on. For more information on this read the document available at the following URL.
http://www.cisco.com/en/US/products/hw/wireless/ps5279/products_tech_note09186a0080508551.shtml
