Frequency AIR-CAP1602I-E-K9
Feker Miri
I have 3 question:
1) it's possible to change a country in AIR-CAP1602I-E-K9 mode AP? If Yes how?
2) How to fix a frequency in band 5 GHz?
3) How disable a DFS configuration?
Thx
Leo Laohoo
Not possible.
It's better to talk to the vendor to replace the AP with the correct regulatory domain.
Scott Fella
Just to add to Leo's post
You can't
You can't since this is regulated.
-Scott
thak you for your support
harvisin
Level 3
Level 3
Hello Feker,
The answer for your 3 questions the answer is No.
Ans:- NO, it is not possible, please contact the vendor.
NO, it cannot be fixed.
NO, the DFS can not be disabled.
