Funny things with Wireless/SDM
g.lacoursiere
Level 2
Level 2
Hello every one,
I am trying to configure Wireless with SDM and all my patience (it is so long after you click on apply !!). I am using a 2801 router. So when I try to create a SSID with a Vlan on my 802.11g (Routing), I fill in everything according to my needs, and when I click on apply, an error shows in my web browser saying that "The web page cannot be found". So to make sure that Wireless SDM is installed correctly, I have updated SDM/Wirless from Cisco web site. I did downgrade and upgrade few times to make sure. Does anyone have an answer for that ??
Also, why is SDM/Wireless so slow, and is there a way to arrange that.
Thank you in advance.
marc.lehner
Community Member
I have the same problem - did your issue resolve?
marc.lehner
Community Member
IOS 12.4(15)T resolves that problem. Was able to successfully move changes from the wireless application in SDM to the router.
