Generate Certificates for WLC and clients
maucapina
Hi Guys
I've been working acording the following document to integrate my WLC 5508 with LDAP for internal users:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/100590-ldap-eapfast-config.html
However when I try to generate the device certificate on Windows Server 2012, I see the steps are different, for example when I reach the step 4 (of Generate a Device Certificate for the WLC section), the CA ask me for a Certificate Signing Request instead of Create and submit request to this CA option, as appears in the document.
How do I get this?
Thanks in advance for your support!
Marcelo
Rasika Nayanajith
If you are trying to get a device certificate for WLC, then you may need to use 3rd party software like openSSL for this.
Below post may help you to see how you can do this
http://mrncciew.com/2013/04/22/configuring-eap-tls-on-wlc/
Rasika
*** Pls rate all useful responses ****
