get out wireless console
pcfreak49
Level 7
Level 7
how can you get out from the wireless console
because I ctrl + - is not working and
6 Replies 6
Surendra BG
Press (CTRL  + SHIFT + 6 ) Release and then press X
Its CTRL SHIFT 6 then release X
This will get you to router mode.. then issue the command DISCONNECT..
Surendra BG
I've
tried
that
but
does not work?
sayrmatics
could you give a bit more details about what u mean when you say get out of a wireless console? would that be terminating a cli session to a controller or to an ap?are you connecting from another device,eg a switch with a wism installed or directly?
just want to get out of the console ap
I did it and it works but the wireless console remains open how can you close?
Command "clear line *"
