Showing results forĀ
Search instead forĀ
Did you mean:Ā
Getting an Air 2700 AP to join to a 5508 WLAN Contoller
corey.cheever1
I'm doing a new setup of a 5508 WLAN Controller and Air-2700 WAP's the AP's wont joing to the controller the controller does see them I do get and error on the AP reading
Not in Bound state.
*Mar  1 00:03:40.943: %LWAPP-4-CLIENTEVENTLOG: Invoking capwap discovery
*Mar  1 00:03:44.015: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.151.192, mask 255.255.252.0, hostname ap00221
Not in Bound state.
*Mar  1 00:05:16.399: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.151.192, mask 255.255.252.0, hostname ap00221
I know its a configuration problem I just not clear on how to fix it.
As i suspected you are running older code. See matrix http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Id suggest the latest 8.0 code or if you like to cowboy go to the latest 8.2.
If this was helpful and fixes your issues kindly rate helpful post!
Product Version.................................. 7.4.121.0
8 Replies 8
George Stefanick
What is the full part number of your access points.
Air-CAP2702E-B-K9
what controller code ?
I'm confused on that question.
On the 5508
attached is the code
That was the problem and I went Cow boy using 8.2 so far no problems.
