gprs problem connection
fsamper
Community Member
I have a problem with a gprs connection.I have remotes router call out for gprs to central router.
These call are good but the tcp sessions are stablished are misfire. My central router is connected to them by tunnels.
My dialer in remote router configuration
interface Dialer30
description llamada apn privado
ip address negotiated
ip mtu 1460
ip nat outside
encapsulation ppp
no ip route-cache
dialer pool 30
dialer string "*99***1#"
dialer watch-group 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname ********@domain.es
Can anybody help me?
umedryk
Level 11
Level 11
Did you check all the access control lists properly - whether they are allowing only the intended networks etc. Most of the times, these kind of problems are related to improper ACLs
