Guest Anchor 5508 Control Path Down
Jacob Jennings
I am having an issue with getting mobility to form between a 2504 and a 5508 controller.  Both WLCs are running 7.4.110.0 code.  The 5508 is the guest anchor.
The 5508 has a management interface on the inside network and the guest traffic is on the DMZ.  On the management interface, that network also hosts another wireless controller for that site.  With the foreign anchor, which is at a remote site, the mobility group is coming up with the non guest anchor, but not the guest anchor.  I only mention this because all of the controller control traffic is passing L3 to one controller, but is not working on the other.  This was set up just to verify that the L3 traffic was reaching that network.
The controller (XYZ) that is in the same network as the guest anchor is a 2104 running 7.0.235.0.
GUEST ANCHOR
(Cisco Controller) >show mobility summary
Mobility Architecture ........................... Flat
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... GUEST
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0x5f38
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 2
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address        IP Address       Group Name                        Multicast IP     Status
bc:16:65:f8:68:60  10.0.200.100     GUEST                             0.0.0.0               Up
ec:e1:a9:54:1e:20  10.44.200.10    ABC                                 0.0.0.0               Control Path Down
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... bc:16:65:f8:68:6f
IP Address....................................... 10.0.200.100
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.0.200.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 200
Quarantine-vlan.................................. 0
Active Physical Port............................. LAG (13)
Primary Physical Port............................ LAG (13)
Backup Physical Port............................. Unconfigured
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 10.44.200.250
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Enabled
FOREIGN ANCHOR
Default Mobility Domain.......................... ABC
Mobility Domain ID for 802.11r................... 0xcb94
Mobility Group Members Configured................ 3
00:24:97:8f:a8:60  10.0.200.10       XYZ                            0.0.0.0          Up
bc:16:65:f8:68:60  10.0.200.100     GUEST                             0.0.0.0          Control Path Down
ec:e1:a9:54:1e:20  10.44.200.10     ABC                        0.0.0.0          Up
MAC Address...................................... ec:e1:a9:54:1e:2f
IP Address....................................... 10.44.200.10
IP Gateway....................................... 10.44.200.1
Primary DHCP Server.............................. 192.168.1.6
L2 Multicast..................................... Disabled
Debugs:
FOREIGN ANCHOR
(Cisco Controller) >debug mobility keep-alive enable
(Cisco Controller) >*ethoipSocketTask: Oct 21 13:20:19.596:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.10:version=02:SeqNo=1187:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:20:19.596:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.10:version=02:SeqNo=1187:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:19.597: Updated client count to 0 for peer 10.0.200.10
*mmMobility: Oct 21 13:20:20.761: Mobility Member 10.0.200.100 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:20:24.411:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.100:version=02:SeqNo=697:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:20:24.412:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.100:version=02:SeqNo=697:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:24.412: Updated client count to 0 for peer 10.0.200.100
*ethoipSocketTask: Oct 21 13:20:29.595:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.10:version=02:SeqNo=1189:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:20:29.595:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.10:version=02:SeqNo=1189:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:29.595: Updated client count to 0 for peer 10.0.200.10
*mmMobility: Oct 21 13:20:30.761: Mobility Member 10.0.200.100 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:20:34.410:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.100:version=02:SeqNo=698:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:20:34.410:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.100:version=02:SeqNo=698:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:34.410: Updated client count to 0 for peer 10.0.200.100
*ethoipSocketTask: Oct 21 13:20:39.593:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.10:version=02:SeqNo=1191:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:20:39.594:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.10:version=02:SeqNo=1191:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:39.594: Updated client count to 0 for peer 10.0.200.10
*mmMobility: Oct 21 13:20:40.761: Mobility Member 10.0.200.100 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:20:44.409:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.100:version=02:SeqNo=699:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:20:44.409:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.100:version=02:SeqNo=699:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:44.409: Updated client count to 0 for peer 10.0.200.100
*ethoipSocketTask: Oct 21 13:20:49.592:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.10:version=02:SeqNo=1193:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:20:49.592:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.10:version=02:SeqNo=1193:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:49.592: Updated client count to 0 for peer 10.0.200.10
*mmMobility: Oct 21 13:20:50.761: Mobility Member 10.0.200.100 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:20:54.407:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.100:version=02:SeqNo=700:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:20:54.407:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.100:version=02:SeqNo=700:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:54.407: Updated client count to 0 for peer 10.0.200.100
*ethoipSocketTask: Oct 21 13:20:59.590:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.10:version=02:SeqNo=1195:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:20:59.590:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.10:version=02:SeqNo=1195:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:59.591: Updated client count to 0 for peer 10.0.200.10
*mmMobility: Oct 21 13:21:00.761: Mobility Member 10.0.200.100 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:21:04.406:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.100:version=02:SeqNo=701:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:21:04.406:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.100:version=02:SeqNo=701:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:04.406: Updated client count to 0 for peer 10.0.200.100
*ethoipSocketTask: Oct 21 13:21:09.589:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.10:version=02:SeqNo=1197:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:21:09.589:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.10:version=02:SeqNo=1197:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:09.589: Updated client count to 0 for peer 10.0.200.10
*mmMobility: Oct 21 13:21:10.761: Mobility Member 10.0.200.100 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:21:14.404:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.100:version=02:SeqNo=702:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:21:14.404:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.100:version=02:SeqNo=702:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:14.404: Updated client count to 0 for peer 10.0.200.100
*ethoipSocketTask: Oct 21 13:21:19.587:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.10:version=02:SeqNo=1199:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:21:19.587:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.10:version=02:SeqNo=1199:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:19.588: Updated client count to 0 for peer 10.0.200.10
*mmMobility: Oct 21 13:21:20.761: Mobility Member 10.0.200.100 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:21:24.402:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.100:version=02:SeqNo=703:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:21:24.403:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.100:version=02:SeqNo=703:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:24.403: Updated client count to 0 for peer 10.0.200.100
*mmListen: Oct 21 13:21:29.386: Vlan List payload not found, ignoring ...
*mmListen: Oct 21 13:21:29.386: IP Address don't compare for client cc:3a:61:08:21:94 is 0
*mmListen: Oct 21 13:21:29.386: cc:3a:61:08:21:94 Ignoring Announce, client record for not found
*ethoipSocketTask: Oct 21 13:21:29.586:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.10:version=02:SeqNo=1201:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:21:29.586:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.10:version=02:SeqNo=1201:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:29.586: Updated client count to 0 for peer 10.0.200.10
*mmListen: Oct 21 13:21:30.386: Vlan List payload not found, ignoring ...
*mmListen: Oct 21 13:21:30.386: IP Address don't compare for client cc:3a:61:08:21:94 is 0
*mmListen: Oct 21 13:21:30.386: cc:3a:61:08:21:94 Ignoring Announce, client record for not found
*mmMobility: Oct 21 13:21:30.761: Mobility Member 10.0.200.100 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:21:34.401:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.100:version=02:SeqNo=704:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:21:34.401:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.100:version=02:SeqNo=704:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:34.401: Updated client count to 0 for peer 10.0.200.100
*ethoipSocketTask: Oct 21 13:21:39.585:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.10:version=02:SeqNo=1203:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:21:39.585:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.10:version=02:SeqNo=1203:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:39.585: Updated client count to 0 for peer 10.0.200.10
*mmMobility: Oct 21 13:21:40.761: Mobility Member 10.0.200.100 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:21:44.399:  Keepalive:VALID:ETHOIP_OP_REQ:Received from 10.0.200.100:version=02:SeqNo=705:receiverStatusOnTransmitter=1
*ethoipSocketTask: Oct 21 13:21:44.400:  Keepalive:VALID:ETHOIP_OP_RESP:Sent to 10.0.200.100:version=02:SeqNo=705:receiverStatusOnTransmitter=0
GUEST ANCHOR
(Cisco Controller) >*mmListen: Oct 21 13:20:10.103: MAC: 00:24:97:8f:a8:60 not found in Mobility Database
*mmMobility: Oct 21 13:20:24.918:  Keepalive:VALID:ETHOIP_OP_REQ:Sent to 10.44.200.10:version=02:SeqNo=697:receiverStatusOnTransmitter=1
*mmMobility: Oct 21 13:20:24.918: Mobility Member 10.44.200.10 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:20:24.929:  Keepalive:VALID:ETHOIP_OP_RESP:Received from 10.44.200.10:version=02:SeqNo=697:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:24.929: Updated client count to 0 for peer 10.44.200.10
*mmMobility: Oct 21 13:20:34.918:  Keepalive:VALID:ETHOIP_OP_REQ:Sent to 10.44.200.10:version=02:SeqNo=698:receiverStatusOnTransmitter=1
*mmMobility: Oct 21 13:20:34.918: Mobility Member 10.44.200.10 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:20:34.929:  Keepalive:VALID:ETHOIP_OP_RESP:Received from 10.44.200.10:version=02:SeqNo=698:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:34.929: Updated client count to 0 for peer 10.44.200.10
*mmListen: Oct 21 13:20:40.103: MAC: 00:24:97:8f:a8:60 not found in Mobility Database
*mmMobility: Oct 21 13:20:44.918:  Keepalive:VALID:ETHOIP_OP_REQ:Sent to 10.44.200.10:version=02:SeqNo=699:receiverStatusOnTransmitter=1
*mmMobility: Oct 21 13:20:44.918: Mobility Member 10.44.200.10 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:20:44.929:  Keepalive:VALID:ETHOIP_OP_RESP:Received from 10.44.200.10:version=02:SeqNo=699:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:44.929: Updated client count to 0 for peer 10.44.200.10
*mmMobility: Oct 21 13:20:54.918:  Keepalive:VALID:ETHOIP_OP_REQ:Sent to 10.44.200.10:version=02:SeqNo=700:receiverStatusOnTransmitter=1
*mmMobility: Oct 21 13:20:54.918: Mobility Member 10.44.200.10 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:20:54.929:  Keepalive:VALID:ETHOIP_OP_RESP:Received from 10.44.200.10:version=02:SeqNo=700:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:20:54.929: Updated client count to 0 for peer 10.44.200.10
*mmMobility: Oct 21 13:21:04.918:  Keepalive:VALID:ETHOIP_OP_REQ:Sent to 10.44.200.10:version=02:SeqNo=701:receiverStatusOnTransmitter=1
*mmMobility: Oct 21 13:21:04.918: Mobility Member 10.44.200.10 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:21:04.929:  Keepalive:VALID:ETHOIP_OP_RESP:Received from 10.44.200.10:version=02:SeqNo=701:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:04.929: Updated client count to 0 for peer 10.44.200.10
*mmListen: Oct 21 13:21:10.103: MAC: 00:24:97:8f:a8:60 not found in Mobility Database
*mmMobility: Oct 21 13:21:14.737:  Keepalive:VALID:ETHOIP_OP_REQ:Sent to 10.44.200.10:version=02:SeqNo=702:receiverStatusOnTransmitter=1
*mmMobility: Oct 21 13:21:14.737: Mobility Member 10.44.200.10 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:21:14.748:  Keepalive:VALID:ETHOIP_OP_RESP:Received from 10.44.200.10:version=02:SeqNo=702:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:14.748: Updated client count to 0 for peer 10.44.200.10
*mmMobility: Oct 21 13:21:24.737:  Keepalive:VALID:ETHOIP_OP_REQ:Sent to 10.44.200.10:version=02:SeqNo=703:receiverStatusOnTransmitter=1
*mmMobility: Oct 21 13:21:24.737: Mobility Member 10.44.200.10 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:21:24.748:  Keepalive:VALID:ETHOIP_OP_RESP:Received from 10.44.200.10:version=02:SeqNo=703:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:24.748: Updated client count to 0 for peer 10.44.200.10
*mmListen: Oct 21 13:21:29.721: MAC: 00:24:97:8f:a8:60 not found in Mobility Database
*mmListen: Oct 21 13:21:30.721: MAC: 00:24:97:8f:a8:60 not found in Mobility Database
*mmMobility: Oct 21 13:21:34.737:  Keepalive:VALID:ETHOIP_OP_REQ:Sent to 10.44.200.10:version=02:SeqNo=704:receiverStatusOnTransmitter=1
*mmMobility: Oct 21 13:21:34.737: Mobility Member 10.44.200.10 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:21:34.748:  Keepalive:VALID:ETHOIP_OP_RESP:Received from 10.44.200.10:version=02:SeqNo=704:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:34.748: Updated client count to 0 for peer 10.44.200.10
*mmListen: Oct 21 13:21:39.921: MAC: 00:24:97:8f:a8:60 not found in Mobility Database
*mmMobility: Oct 21 13:21:44.737:  Keepalive:VALID:ETHOIP_OP_REQ:Sent to 10.44.200.10:version=02:SeqNo=705:receiverStatusOnTransmitter=1
*mmMobility: Oct 21 13:21:44.737: Mobility Member 10.44.200.10 detected DOWN status 2, cleaning up client entries
*ethoipSocketTask: Oct 21 13:21:44.748:  Keepalive:VALID:ETHOIP_OP_RESP:Received from 10.44.200.10:version=02:SeqNo=705:receiverStatusOnTransmitter=0
*ethoipSocketTask: Oct 21 13:21:44.748: Updated client count to 0 for peer 10.44.200.10
Any ideas?
6 Replies 6
It's looks like your mobility member configuration is wrong.
As per the below line "ec:e1:a9:54:1e:20" WLC should be in XYZ mobility domain.
ec:e1:a9:54:1e:20  10.44.200.10     XYZ                              0.0.0.0          Up
But you have configured it for different mobility domain name in the first controller.
Please check the mobility members configuration again & let us know.
Rasika
**** Pls rate all useful responses ****
I made some modifications because I believe I messed it up when sanitizing it.
There are three controllers
XYZ and GUEST are L2 adjacent.
ABC is across a WAN link.
ABC needs to connect to GUEST.
XYZ and ABC are connected only to show that the L3 path is working correctly.
Here is a quick diagram to help grasp the situation.
http://i39.tinypic.com/hwwrd2.jpg
Hi Jacob,
Thanks for the diagram posted, it really helped to understand what you are trying to do. If you simply want guest anchoring ABC to GUEST, simply configure the mobility group members as follows (I think you alreday done that).
config mobility group domain GUEST
config mobility group member add ec:e1:a9:54:1e:20  10.44.200.10     ABC
config mobility group domain ABC
config mobility group member add bc:16:65:f8:68:60  10.0.200.100     GUEST
If mobility tunnels not coming up you  have to check UDP port 16666 & EoIP reachability between your two controllers. Do the following "mping" & "eping" testing from remote controller (mobility domain configured with ABC)
(WLC-ABC) >mping 10.0.200.100
(WLC-ABC) >eping 10.0.200.100
if both succuess your mobility tunnel should come up. If mping fail, then udp 16666 is blocked somewerhe your Guest WLC &  remote WLC. If  eping fails then EoIP is get blocked somewhere Guest WLC & remote.
Rasika
*** Pls rate all useful responses *****
eping is successful but mping fails.
Like I said, ABC can eping and mping XYZ but not GUEST.
GUEST is connected to the same switch as XYZ with the same VLAN.  I am not what could possibly be blocking that traffic layer 2.
Does these two controllers having same virtual IP address ? Makesure it is the case.
Also post "show sysinfo" output of both Guest & ABC controllers just to verify MAC address information again.
Rasika
I am having the same issue with the software version 7.3.112. Did you find a solution?
Stephane
