Issues with DHCP, cisco 871w
djjasonsa1
Hi all,
Recently purchased a 871w, from what I can see all the config is as it should be.
The dhcp is working on the fa ports but not the wifi hence it could be a bridging issue:/
Here is my config minus passwords. Any pointers would be brilliant
Current configuration : 2626 bytes
! Last configuration change at 12:36:43 UTC Thu Jul 28 2011
version 15.1
no service pad
service password-encryption
hostname HOMERTR
boot-start-marker
boot system flash:/c870-advipservicesk9-mz.151-4.M7.bin
boot-end-marker
no aaa new-model
dot11 syslog
dot11 ssid Home_New
authentication open
authentication key-management wpa
guest-mode
infrastructure-ssid
wpa-psk ascii ***********
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.50.3.1 10.50.3.3
ip dhcp pool LAN
network 10.50.3.0 255.255.255.0
default-router 10.50.3.1
domain-name home
dns-server 10.50.3.1 8.8.8.8
ip cef
ip name-server 8.8.8.8
ip name-server 4.2.2.2
no ipv6 cef
bridge irb
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description BT INFINITY
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 1
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
ssid Home_New
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description INSIDE LAN
ip address 10.50.3.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
bridge-group 1
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname bthomehub@btinternet.com
ppp chap password *********
ppp pap sent-username bthomehub@btinternet.com password 7 053B071C325B411B1D
interface BVI1
description $ES_LAN$
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended BTINFINITY_ACCESSLIST
permit ip 10.50.3.0 0.0.0.255 any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
exec-timeout 0 0
no modem enable
line aux 0
line vty 0 4
login
transport input telnet ssh
scheduler max-task-time 5000
end
Abha Jha
Please put no IP address under interface vlan1 and put the IP address which is there under vlan1 to BVI1.
