Bookmark
Subscribe
2189
Guest reauth. again and again
ittechk4u1
Level 4
Level 4
Hello Experts,
I configured CWA (WLC / ISE) and its working but...Guest users are complaining about re-authentication again ad again after few minutes.
can anyone help about it ?
2 Accepted Solutions
Sandeep Choudhary
check these:
1. Did you disable session timeout(by default 1800) on WLAN or did you increased it (8x60x60seconds)!!!
2. How did you configured your authZ policies ?
  - Here you can send idle timeout and sessiontimeout with RADIUS Attributes!!!
Dont forget to rate helpful posts
ok. Then you push Idle Timeout/session-timeout radius attribute from AutZ profile and try again.
Check this pic:
5 Replies 5
Sandeep Choudhary
check these:
Thank you Sandeep.
Yes I disabled the session timeout still facing the same issue..
Check this pic:
Ok I will add these parameter and let you know the results.
Thanks again for quick answer.
Thanks you sandeep, its working.
