guest ssid ip learn problem
Abhishek766
Visitor
when i tried to connect on temporary ssid, it pick temp vlan pool but then i try to hit on guest ssid then it assign guest ip pool and no redirection to guest portal but wlc 9800 show ip pool temp ssid then i delete the client & then it will pick guest ssid and redirection done whats the issue when i do manually delete the client it works.
Mark Elsen
  - @Abhishek766              Investigate full client behavior with instructions from :
                                            https://logadvisor.cisco.com/logadvisor/wireless/9800/9800ClientConnectivity
                                         The results, so called RadioActive Traces can be analyzed with :
        Debug Analyzer
                                         And also checkout instructions from : https://logadvisor.cisco.com/logadvisor/wireless/9800/9800CWA
                                        Validate the overall configuration of your 9800 wireless controller using
                                        the CLI command show tech wireless and feed the output from that into   :
        WCAE
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
carpetland-ae
Level 2
Level 2
This sounds like the client session is not being cleared properly when switching SSIDs. Since deleting the client manually immediately fixes the issue, I’d check the WLC 9800 client session/state, VLAN assignment, and authentication/redirect policies. Comparing the client details before and after deleting the session may help identify what is being cached.
