Guest Users - Web Auth
Wellington L
Level 3
Level 3
I need to know about one case using web authentication with guest users.
I have a environment where when i created the user in NCS using the looby account the user can authenticantee many times during a period but in a lot of machines at same time.
Can i put some option to restrict the user to authenticatee in only one machine and if another user try to authenticatee too, the wlc blocks ?
Another question is about the looby user will be in the RADIUS Server and this creates the guest users in the local database. Can i do it ?
Thanks.
Stephen Rodriguez
Yes, you can limit the number of concurrent logins.  Under Security > User login policies set this to the number of logins you want to allow.
As for the Lobby admin being in Radius ,you can do this as well.
https://supportforums.cisco.com/docs/DOC-8383
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
