Guest WIFI and Achore controller
We are planning guest only WIFI in our LAN campus with Achor controller. I need some clarification.
1- IF we install Cisco APs in LAN  and Anchor controller in DMZ  only. Is the tunnel between Guest SSID and Anchor controller?
2-  do we need corporate controller in WLC in LAN ?
We will install corporate wifi in future but no plan yet. Therefore only need to purchase anchor controller for guest wifi.
Regards.
Correct!
Internal WLC will handle the corp ssid traffic and for guest ssid, it will create a EOIP tunnel with anchor WLC and terminate all guest traffic there .
Dont forget to rate helpful posts
5 Replies 5
Sandeep Choudhary
You should have:
1. A internal WLC(Foreign) and a DMZ WLC (Anchor)
2. configure Mobility between both conftrollers
3. Use a Radius server (Cisco ISE) to create guest users and to push the webauth page to guests.
check here: https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-1/Enterprise-Mobility-8-1-Design-Guide/Enterprise_Mobility_8-1_Deployment_Guide/WirelessNetwork_GuestAccessService.html
 here is the answers of your questions:
 Mobility tunnel will be between foreign (Internal)WLC and anchor WLC
I think you are talking about internal wlc..then yes.
Thanks Sandeep,
My understanding is internal WLC is for corporate WIFI and we only need guest WIFI. Is there any otherway that AP can do directley tunnel between SSID in AP and anchor controller like Meraki does between AP and Concentrator MX firewall.
Regards.
It will not work.
If your AP is in LAN ...where you will join these AP? ...(You will need a Internal controller in LAN so thats these AP can join to it)
Thanks Sandeep,
Apology for not understanding the concept. If I understand correctly we can not register APs directly to anchor controller ( which is just like a concentrator to terminate the tunnel) and all the AP registration and SSID configuration ( guest and corp) happen on internal WLC? and we have to buy it and can later configure corporate WIFI  on internal WLC later?
Regards.
Correct!
