Guest Wireless network security
b.bader
Visitor
Hello all,
I have a client that we configured a custom splash page for their guest wireless network.  Upoloaded to the WLC just fine. Redirects just fine.  Where the customer is located, they are concerned with only having an "accept" button on the splash page.  They are asking to use a PSK on the SSID along with the splash page.  So basicly after you enter the PSK on for the SSID, it would then redirect you to the custom splash page.
The WLC (7.X code... unsure of the exact version) allows for this configuration, but it seems to completely ignore the PSK and leaves the SSID open with the splash page.  I cannot find any reference to this configuration not being allowed, or specificalyl allowed either.
Anyone know of a way to make this work?
Bryan Bader
MSN Communications
Scott Fella
It should work... PSK is layer 2 and the WebAuth is layer 3. If they are anchoring then they need to make sure they implement that change to the foreign WLC also.
-Scott
Ravi Singh
Level 11
Level 11
Scott is absolutely right. It should work because PSK works on L2 and Webauth workes on L3. I think there is problem in your configuration please double check it.
