WLC 2504 Power Consumption
Anyone knows what is the power consumption of WLC 2504.
Regards!!!
5 Replies 5
Saravanan Lakshmanan
just guessing.
2500 power adapter reads output as 48V and 1670mA for current.
power = voltage * current
power= 48 * 1670 = 80 Watts
Thanks a lot!!
Regards!!!
you are welcome!!
http://www.cisco.com/en/US/docs/wireless/controller/2500/quick/guide/ctr2504_q_s.html
When multiple 2504 controllers are mounted in an  equipment rack, be sure that the power source is sufficiently rated to  safely run all the equipment in the rack (input: 100 to 240 VAC, 50-60  Hz, output: 80 W per controller).
Ravi Singh
Level 7
Level 7
It is 80 watt around which may be reduce by turning off access point radios to reduce power consumption during off-peak hours
