Guest wlan WEB authentication and ip address logging
l.buschi
Level 2
Level 2
my costumer wants to deploy a web authentication for a guest SSID with 8.x WLC.
As my costumer wants to log all internet activity of the guest users I need a way to log the association guest-username/IP address assigned by dhcp.
Is it possibile to achieve this goal with internal WLC web authentication?
If it isn't, is it possibile to do this using a radius microsoft server with web authentication?
Thank you very much
Johnny
Hi @l.buschi
 You can see those information on the SNMP trap logs, under MANAGEMENT tab. If you have Cisco Prime, those trap is sent to the Prime dashboard, if not, you can send this to a thirdy-part NMS.
 The log you should see is something like:
Client Authenticated: MAC Address:x.x.x.x.x  base Radio MAC:x.x.x.x.x  Slot: 0 User Name:aaaaaaa@bbbbbbbbbb   IP Addr:x.x.x.x.x  SSID:MMMMMMM
-If I helped you somehow, please, rate it as useful.-
Hi @l.buschi
Tks Flavio,
It works!
