HA configuration between (2) 5508 controllers with 12 licenses each
Steve Coady
Hello
Can HA be configured on Cisco 5508controllers with 12 licenses each. Is there a minimum license requirement?
Product Version.................................. 7.4.121.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
sMc
sMc
9 Accepted Solutions
Scott Fella
Minimum is 50 AP license to run HA.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Here you go.
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1130-ag-series/qa_c67-714540.html
Q.
I already have a spare controller. Can I convert that controller to the standby controller?
A. Yes. Customers need to upgrade their controller software to Release 7.3. They can then convert the spare to a standby controller using the command-line interface or GUI.
It is important to note that on the Cisco 5508, the controller needs to have at least 50 access point licenses in order to be able to convert the controller to the standby controller for the wireless LAN.
Scott
-Scott
Just adding to scott:
if you have 2 wlc with each 12 ap licence then you can configure AP failover:
Local on AP
Wireless > Access Points > All APs > Select AP > High Availability Configuration
or
Global
WIRELESS >Global Configuration
check here:
http://rscciew.wordpress.com/2014/01/22/ap-failover/
regards
For true redundancy, you either can get another WLC with the same # of access point licenses, but if you have more than 50 AP's, then just either look at the cost for an HA sku wlc compared to the cost of adding licenses to get to 50 AP.
Scott
-Scott
If you have less than 12 AP's, just follow what Sandeep posted and assign the primary and secondary WLC's to each AP.
Scott
-Scott
No specific hardware if you have one with 50 licneses... but it might be cheaper to get an HA sku WLC.
Scott
-Scott
Here is the part number so you can compare the cost: AIR-CT5508-HA-K9
Scott
-Scott
just to add:
You either need the  standby controller (either WLC HA sku controller or a WLC5508 with 50 AP license or more) to run HA AP SSO.
Primary controller : With enough license (Example:100 AP license)
Secondary or standby Controller:  HA-SKU license or a WLC5508 with 50 AP license
Hope this is more clear.
Dont forget to rate helpful posts
Make sure you are running the latest FUS image... seem's like you are not by looking at this:
Upgrade to FUS 1.9.0.0.. here is the release notes:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus_rn_OL-31390-01.pdf
Download the FUS here.... the process will take around 35-45 minutes in which you will not be able to acess the WLC.  You should console into the WLC to see the progress of the upgrade.
http://software.cisco.com/download/release.html?mdfid=283848165&flowid=24841&softwareid=284364857&release=1.9.0.0&relind=AVAILABLE&rellifecycle=&reltype=latest
Scott
-Scott
13 Replies 13
Scott Fella
Scott
-Scott
Here you go.
Q.
Scott
-Scott
Scott
Thank you for the reply
What other options do I have for failover/standby between controllers?
sMc
sMc
Local on AP
or
Global
check here:
regards
Scott
-Scott
Scott
-Scott
Scott
sMc
sMc
Steve Coady
Sandeep
Thank you for the reply.
I new of the High availability option on the AP's. Due to the push to use HA, I was not sure if the
controllers had another failover option
sMc
sMc
Hello
Is there a specific HA license that has to be purchased or is HA automatically available if the minimum License
requirement is met?
sMc
sMc
Scott
-Scott
Scott
-Scott
just to add:
Scott
-Scott
