HA SS0 'Invalid Input'
j22dodge
Community Member
I am trying to configure HA-SSO (RMI+RP) between two 9800-CL controllers.  Both running 17.6.4.  Chassis 1 seems to work just fine.  But chassis two gives me this message every time.
"  redun-management interface chassis 1 address 10.89.240.114 chassis 2 address 10 ^.89.240.115
Invalid input detected at '^' marker.  "
Any ideas about what the issue could be?
Thanks in advance.
5 Replies 5
 Did you add some space or characte on the IP address?
This a real log copy or did you type it?
It seems theres something wrong
That is copied from the log error.
Did you try to delete the IP and enter again? Maybe do from CLI instead
I have tried Deleting the IP and re-adding it.  Also does not seam to work.  I have also tried configuring it through the CLI, it takes, but they do not pair.
Scott Fella
Factory reset the secondary unit and start over.  That should fix the issue if the issue is with the secondary.
-Scott
