have one cisco wireless controller CISCO2106 . i have configured mangement interface and AP-manager interface into that. I can now login to WLC through management interface, But the problem is AP-manager interface is not coming UP so the AP are not assoc
sumeet kumar
16 Accepted Solutions
dmantill
Level 4
Level 4
What do you mean it is not UP? Can you please upload config and debugging? What output do you see on the AP side using the console port?
What is the discovery method?
Hi Sumeeth,
Thanks for uploading the info!!
The AP manager interface is the NON-PINGABLE interface.. what ur able to see is the expected behaviour.. the AP manager IP should not be pinged..
However, from the config i saw ur management and the AP manager are assigned to dofferent ports.. please issue the command and lemme know if that resolves the issue..
interface port ap-manager 1
Please lemme know if this answered ur question and mark it as answered if so!!
Surendra
Surendra BG
Hi Sumeeth,
config interface port ap-manager 1
Surendra
Surendra BG
Is the LAG enabled on the WLC??
Surendra
Surendra BG
Ok.. please map the AP manager to port 1 and then reboot the WLC.. in the mean time cature the console logs from the AP.. to see the reason why the AP is not able to get registered..
Surendra
Surendra BG
any update??
Surendra
Surendra BG
Please go through the below links and proced further.. U get more info on the same!!
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
Lemme know if this helps
Surendra
Surendra BG
Could you please reply back wiht SHOW RUN-CONFIG and not the RUNNING-config..?
Let us know if the APs are getting registered.
wat does the debug say on the WLC??
I guess i hv already provided this doc.. giving you again.. please refer to this or please read this and this will help you!!
Surendra
Surendra BG
There got to be a duplicate IP address on your network, why dont you check on that?
Check at first if some other device is using management and or ap-manager..
please reply with show run-config and give us an idea of the topology, routing , IP ranges, etxc...
download  it from cisco.com, or get a contract, or contact TAC.....
please make sure that you are not having duplicate IP addresses.
If you have skype I can help you right now... diego_mancr
are the APs getting the IP address?? what does debug on the WLC say??
Surendra BG
As per debug
Ap sends discovert and WLC transmit discovery response....
But what happend then? we need all the debug output from at least 1 AP.
@Surendra: can you setup a webex session with him to help him over this on your schedule? unfortunately it seems like we are not even able to find each other during my day....
i can help you right now
Can you please add me to skype? I can help you now... but please I need you to contact be thru a faster method...
45 Replies 45
dmantill
Level 4
Level 4
Hi Thanks for reply,
Pls find the attached config and debug
i can able to ping management interface but can not ping Ap-manger interface.
Pls help ...
Hi Sumeeth,
Surendra
Surendra BG
Hi Surendra,
Thanks but in this model WLC if you assign same interface port for both the mac address will be same for both interface thats waht i made AP manager interface on port 2 even though if i make both on port 1 AP not associating with WLC
Surendra
Surendra BG
No there is no option to enable the LAG in this model
You can chat with me in gmail ID sumeetf
uture@gmail.com
No problem!! i am active here
Surendra
Surendra BG
Surendra
Surendra BG
Pls find the report after changing the AP-manager port. This device is on remote location, So no console is connected...
Surendra
Surendra BG
Ap is not getting registered
