Heat maps
how to generate Heat maps for wireless site survey.
Scott Fella
You need to use a surveying software like AirMagnet or Eckahu. There is nothing that is free.
-Scott
I download the software Ekahau Heat mapper and i installed the software .when i  uplaod the maps it automatically create Heat maps .
Saurav Lodh
Level 11
Level 11
