help about 1522AG
mostafa ouamou
Community Member
Hi all,
I deployed wireless mesh with 3 RAP and 1 MAP (AIR-LAP1522AG-E-K9 with 4 antenna) + WLC 2504.
The AIR-ANT2480V-N are instelled on pole from a height of 17-15 m.
I noticed that I can't get a good signal (front of antenna between 40m to 60m I got bettween -60 and -70 dbm) with slow connection.
1) What is the best antenna height on pilone?
2) Can I use other antenna (directional) with AIR-LAP1522AG-E-K9?
3) what is the area covered by antenna?
4) the RAP and MAP establish a neighbor between them and work with same fréquence for Mesh connection. is there any impact with that?
Thanks in advance.
I will be happy to hear your suggestion too.
Take Care.
0 Replies 0
