Help configuring a Cisco 4402 wireless controller
WaynePlotkin
I need help setting up a Cisco 4402 Wireless controller. I want to have users automatically connect to the wireless network, but not have access to any network resources until they open a web browser and supply their domain username and password or a guest account supplied by the receptionist.
I have tried numerous different configurations but can't seem to get it to work properly. More time then not when I set up security on the WLAN it causes my wireless network to disappear from the list of avaialbe wireless networks.
Here is my network Configure:
1 - 4402 wireless LAN Controller
2 - Aironet 1130AG antennas
1 - 5510 Cisco ASA
1 - 4503 Core Router\Switch
8 - 2960G Switches
Windows Server 2003 Domain with Radius running on the Domain Controller.
Thanks in advance for the help.
30 Replies 30
I am having pretty much the same issue but I can 't understand why its not working because this is the message I get in Microsoft IAS...
User xxxx was granted access.
Fully-Qualified-User-Name = xxxxx
NAS-IP-Address = 192.168.1.8
NAS-Identifier = RMCORPWLC01
Client-Friendly-Name = RMCORPWLC01
Client-IP-Address = 192.168.1.8
Calling-Station-Identifier =
NAS-Port-Type =
NAS-Port =
Proxy-Policy-Name = Use Windows authentication for all users
Authentication-Provider = Windows
Authentication-Server =
Policy-Name = WLC Auth
Authentication-Type = PAP
EAP-Type =
For more information, see Help and Support Center at
Any suggestions? I made sure that all my settings matched those discussed in this thread?
This line: Proxy-Policy-Name = Use Windows authentication for all users
Shows that you are not hitting the remote access policy. This is the defualt windows IAS policy.
Can you post your show run-config and tell me what ssid you are using. Might be a configuration on the wlc of your IAS server.
-Scott
Also, check your shared secret configuration with the RADIUS server and make sure it is long enough. I had first set it up with only 10 characters and then changed it to 26 characters and it started working immediately.
FYI...Right now I'm just trying to get this working for MGMT logins, the problem I am having is that I cant login to the device with any username that isnt in the local list.
So you are trying to configure the wlc to authenticate management users when they try to access the wlc? Just note that the wlc will use local, then radius, then ldap if configured.
Here are some links for that:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080782507.shtml
This link is for ACS. what you have to do in the remote access policy in IAS is to set the service type as login. Also u[pgrade your boot loader to 5.0.
-Scott
I have done both of those things...
be carefull with the polices in IAS. If you have another policy using the same nas ip address to authenticate wireless users, it will hit that and fail to the default. if that is your only policy you have, then the ias policy isn't configured right.
-Scott
On you log that you posted: NAS-IP-Address = 10.1.12.35
This isn't your management interface (92.168.1.8) on the WLC? So what device is this you are showing?
-Scott
I dont have any of those IP addresses, Im not sure what you are refering to?? I have more than one policies in IAS, I dont understand why it is so hard to setup RADIUS with this thing? Why would RADIUS behave so much differently on a WLC then say a router/switch?
Post the error you are seeing on your IAS.
-Scott
I am not seeing an error on IAS...I see that access was granted? That is why Im at a loss for why this isnt working?
User david.jack was granted access.
NAS-Port-Type =
NAS-Port =
Policy-Name = WLC Auth <<<<
EAP-Type =
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Youmight have to setup accounting also. Capture data with a sniffer on the port that the wlc is connected to on the switch. If you see authentication pass, but accounting failed, then accounting will have to be setup. On ACS, you have to have that configured in order for this to work.
-Scott
I will have to give that a try, my shared secret is only 7 chars right now.
I'm having the same issue. Did you get it fixed?
