Help, No signal on wap's
donnavancura
I've a wap installed and it's been working fine. Now I have no signal al all. I am new to this facility and don't have much information on this access point. Any ideas?
mmellet
Level 3
Level 3
If there is no connection to any other wireless devices, it could be some sort of RF interference that is causing this problem. You may just need to change the channel on the AP to something other than the usual default of channel 6. Here is a good URL to look over. http://www.cisco.com/warp/public/102/wlan/rf-problems.shtml
ndoshi
Hi ,
Best way to troubleshoot is to put the WAP and Client in FACTORY DEFAUL CONFIG and see if it works .
If it is Cisco Ap , go to Cisco Services -> Manage system config , you will find
reset Ap to factory default
By default AP has ssid -. tsunami
Also look for any RF interference issue like codeless phone , microwave .
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Internetworking:Wireless_LAN_General
