I need help with a 1200 series Aironet. When doing a SH IP INT BRIEF it is showing RESET on the Dot1Radio0 interface.
Dot11Radio0 Status reset
What does this mean? and how to I initiate this interface? is it because I do not have the extended radio antenna plugged in?
Thanks in advance.
BVI1 10.188.100.6 YES NVRAM down down
Dot11Radio0 unassigned YES NVRAM reset down
FastEthernet0 unassigned YES NVRAM up down
**EDIT**
I have consoled into the second WAP with IP 10.188.100.5 and it is not showing this problem.
Could it be that 10.188.100.6 has a damaged or malfunctioning radio antenna?
