HELP: symbol netvision phone w/cisco 350
jserevitch
Hello
I am having trouble setting up a symbol netvision phone with my cisco ap 350 that is running 12.01T. Basically, when the phone powers up it finds the SSID for my network (if i enable the broadcast SSID). It does not seem to get an IP Address/mask. It constantly displays "No Network". I have read the caveats for this release...there is mention that the symbol phone may display this message and there is no workaround present. If anyone has a working config on the AP, please email me at jserevitch@netteks.com. Also it would be good to know if anyone has gotten this to work with release 12.01T. I have symbol extensions enable and the preamble is set to long....Thanks!
Not applicable
I think the only thing you can do is to use Cisco Aironet 1100/1200 AP,instead of Cisco 350 series AP.
This isssue is not present in 1200 and 1100AP.
