Help with Cisco 1242ag Password reset
davebullen
I just purchased a used 1242AG which is running Version 12.4(13d)JA.
I tried the mode button on power on holding for  2-3 seconds, but nothing happens and Cisco/Cisco login does not work.
I have figured out if I hold the mode button in for 30 seconds while powering up I get an AP prompt
I tried doing a dir flash but get permission denied.
Is their any commands I can run at AP prompt to attempt to reflash this unit or reset password somehow?
Surendra BG
ok.. the AP is in AP: prompt is it? if so.. please follow the below document which i wrote just hours back.. lemme know if this helps or ping back and we will help you out!!
https://supportforums.cisco.com/docs/DOC-14636
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
7 Replies 7
Surendra BG
Surendra
Surendra BG
Perfect thanks. I will try tonight when I get home.
What firmware version should I reload to the device?
Just looking now on cisco's site and I don't appear to have access to the latest 3-4 versions, so looks like I May have to download an older version and put on.
Hi Dave,
Here is the link which may help you in downloading the latest image..
http://www.cisco.com/cisco/software/release.html?mdfid=280237322&flowid=7588&softwareid=280805680&release=12.4.25d-JA&rellifecycle=ED&relind=AVAILABLE&reltype=latest
Go for the latest 12.4(25d)JA.
Lemme know if this answered your question, if so please mark it as answered which wil help others!!
Surendra
Surendra BG
When I click download I get the following error:
To Download this software, you must have a valid Technical Support Services Agreement associated to your Cisco.com user ID.
  • If you do not have a Technical Support Services Agreement you can get one through:
    Your Cisco Account Team if you have a direct purchase agreement with Cisco
    Your Cisco Partner or Reseller
The only firmware versions I get this on are ones older then the previous 3-4 releases.
Hmmm.. ok.. then there is 2 options now..
Option 1>> We need to download the older image.
Option 2>> Since you purchased the AP today, this will be under warranty i guess.. so u can open up a TAC case with us and we can help you in getting the image published.
Surendra
Surendra BG
Procedure worked like a charm, was able to successfully reload 12.4-3g.JA1 and login to device with default pw of Cisco.
Thanks again!
Hi Dave,
Thats nice to hear!! Thanks for using CSC.. looking forward to see more posts..
have a great day!!
Surendra
Surendra BG
